I have done some quick searching and can't seem to find any answer. I remember reading somewhere that it was bad for the amp. So, if the box is properly built(3/4" MDF and good bracing) is there any problem in mounting amps to a box?
the rattling of the amp is bad. as long as the amp is on a solid surface then no it not bad its ok. steve has amps on his box
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Do not mount any amp on your box unless it is a last resort, if you do put rubber bushings between the amp and the box to dampen the vibrations.
4 15" dc audio level 4 xl's in 4th order blow through
2 IA 40.1's at 2 ohms strapped with 3.9 rise...currently own 4 IA 40.1s.....
1 06zx3504 running Kicker QS 6 1/2's
1 iraggi 180 amp alt
1 optima d34 yellow top under hood
5 deka intimidators
HU - Eclipse AVX5000 W/ DCU-105
Termlabed 157db at 38hz 6000 watts
My installer says the rattle will loosen up the terminals, so he made me an amp rack :)
Edited by mccanng
2002 Toyota Solara SLE V6
Headunit - Pioneer DEH P3900MP
Door Speakers - Polk Audio db6501 6-1/2" 2-way
Component System
Rear Speakers - Polk Audio db691
Speaker Amp - DD C4b
Sub - 2 12" Alpine Type R's in a 2 @ 33hz
Sub Amp - DD M2A
Electrical - Big 3 - Stinger HPM 1/0 guage Wires, Optima Yellow Top Battery, 180/120 DC HO Alternator w/ MLA
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
refs: DC_Power_Kyle
i didnt have much room so i put mine on the outside port wall with some foam pads under it seems to work ok
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
It is very bad for the amplifier. As soon as you mount the amp to the box, the amp, board and all components absorb every bit of vibration. Meades' setup is different, he has very little flex from over building his enclosure. If at all possible, avoid mounting any amps to enclosures. As suggested above, if you have no choice then atleast use rubber spacers in between the feet and the box.
Mike Stiers
Product Development & Technical Support
Maxxsonics USA
MB Quart , Hifonics , Crunch & Autotek
Car, Home & Marine Audio Products
Maxxsonics YouTube Channel
I'v Had Amps Mounted To My Boxes Before Most Thing That Happened Was The Screws Came Out! Now In All My And My Mom Cars We Have Mounting Walls Put Up!
We Dont Mount To The Seat B.c Our Caddi Seats Dont Fold Down
Team Xtreme Amperage
Xtreme Audio Innovations
XtremeAudioInnovations.com
Facebook.com/xtremeaudio321
4 linked c notched bagged
Fiberglass door panels (5 speakers per door)
I figured it wasn't a good idea, I just wanted a second opinion and I got several. Thanks to all. I just have my ex cab ranger to work with and I've got 3 amps to throw in there. I'll try to figure something out.
3 amps man?
nice, i just got my big 3 done in my ex cab ranger.
gotta get money for HU and then i'ma get me new subs/amp!
99' Ranger XLT Ex Cab Stepside 33'' Bfg M/ts on Black Steelies.
Big 3 Upgrade
Pioneer P3100UB
2 10'' Kicker CompVR's
Ported Box - tuned to 37hz
Directed 2400D
AQ HDC3 On The Way, Box being built Atm, And Amp yet to be purchased!
Look up for your answer? Seen quite a few amp racks along or in headliner. Some looked great some looked
terrible. Just a thought about placement. Thinking about a rollcage looking amp rack in my ext. cab Dakota.
I feel your pain man we dont get much space to begin with. Good luck man.
