Ok so this what happened. I was playing my system when all of a sudden my subs go off and my lights start dimming in and out constantly and I'm like WTF. I check my amp and I notice that the protect light is also flickering, I turn the radio off and it stops but when I turn it back on it starts again. Then I when under the hood and took the fuse out, might I also add that the fuse is hot, then I turn the radio on the flickering stops....until I put the the fuse back in. What do you guys think the problem is? Need some ideas before I start going through my ride :help:
Also about a month and a half ago something like this happen(the fuse wasn't even blown)
I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass.
Open Up The Trunk
Pioneer P6000Ub H.U.
Sundown Saz-1500D
Hifonics ZXi 4410
12" Directed SX12D4 (x2)
12" 1500rms Sub x1
Front - Powerbass 4XL-65-92 Mids
Rear - Cadence 6.5" Mids
Electrical Under Construction
Check Me Out(CarAudio Vids)
Official Feedback Thread
Check Out My Music Page
...no help?
Open Up The Trunk
Sundown Saz-1500D
Hifonics ZXi 4410
12" 1500rms Sub x1
Well the fuse holder has been replaced
Open Up The Trunk
Sundown Saz-1500D
Hifonics ZXi 4410
12" 1500rms Sub x1
Ok, i assume you checked for good grounding and connections all through.
You could try opening the amp up, if there is a problem big enough to dim the lights it should be obvious from a quick look, just make sure it doesnt void your warintee, worth a look though.
check for frayed power wire. replace fuse/fuseholder. check for + and - power wires touching on amp.
heat is usely cused by a lose wire i asume. bad ground
cars rust and if the paint was ground of the metal it will rust that could result in a bad ground
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
yea...either a connection sucks somewhere.......or ur power wire is grounding out somewhere (which has happened to me and my whole car shut off for a split second)
i likes me some audio stuff...
is it hard for people to name their threads besides just "help"
NoFearX18 said:
trainman0978 said:
