Setting gains
DylanH
Is there any way to set the gains on an amp with a DMM. I really dont want to buy an O-scope
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
:mellow: There are tons of topics on here already on how to set your gain with a DMM. Sadly I never saved any of them. Here is a simple way.
Set all the gains on the H/U on zero, or off. Turn the gain on the amp all the way down. Unhook the sub(s) from the amp, and plug the DMM into the amp. Play a 40-50hz tone, you decide which one, all in that range will work (I personally used a 50hz). Now the formula with an example.
Let's say you want 500 RMS. You will find the square root of 500 which is 22.36. So if you are running the amp at 1 ohm, you will want the DMM to read out 22.36. If you are running at 2 ohm, you will want the amp to read out 44.72 (which is 22.36 x 2). So on and so on.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
SWEET!!! Thank you very very much!!
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
the way i go about it is first starting with the dmm leads hooked up in the amps + - terminals. i set the dmm to read ac voltage. i than play decaf's -5.6dB @ 45Hz test tone. I make sure to have the headunit volume set to 3/4. also i turn the sub setting all the way up when i set my gains, this way i will never send my subwoofer a clipped signal. all other settings i keep at 0. such as low,mid,high
when trying to figure out the voltage to set the gains at i first start by looking at the amps fuse rating. for example my amps fuse rating is 150. i take 150 x 14.4(voltage) = 2,160. 2,160 x .707(rms value) = 1,527 watts rms. now say i want to run my amp at 1 ohm. i take 1,527 wrms x 1 ohm = 1,527. take the square root of 1,527 and you get 39.07volts. 39.07 is what i would set my gains to.
hope this doesn't confuse you too much.
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
You forgot to allow for the amp's efficiency loss... probably in the region of 25%...
EDIT: No point doing the RMS conversion either, although you just get lucky enough that it equates to the same as calling the amp 70.7% efficient.
So I call this 'right-ish answer, wrong working'
10.x volts fo' life!
So if i have a audiopipe 3000d bridged at 2ohms , The multimeter should say 109.54... since the square root of 3000 is 54.77...
Is this correct?
TermLab 148.9 @ 39hz BURP
148.8 on music
dont forget thats with a -3 or -5 db 50hz tone as well...
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
hrmm i thought i posted the link to -4.6@45hz, hmm well it was suppose to be -4.6, but i just called it -5
i replaced the tone link i thought, because when i first started the music thread it was -5.6
:censored: , lol :aggressive:
and ur voltage is practically never 14.4v, using 13.8v is a bit more realistic
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
