Can I Wire Mids Like This?
pimpedout97x
basically 2 different mids, wired in parallel, to the same channel on a 2ch amp.
Front and Rear Left in parallel = channel 1
Front and Rear Right in parallel = channel 2
that way the left side (front and rear) would be in the same channel getting the same sound, and the right side (front and rear) would both be in channel 2.
but my real question is, since the front mids are B&C, and the rears are selenium, can i wire it like this? some say yes, some say no.
im pretty sure you can as ong as there 4 ohms or 8 ohms(dont mix match ohms) but thats how mine were ran,the positive ran to the other speaker positive and the negative ran to the other speaker negative 2 single 4's resulting in a 2ohm load
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
i dont see why it wont work
as long as the ohms match the amp ohms then u should be fine
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
ya theyre both 8 ohm
is this your first time hooking up the b&c's or have u heard them before? i never have,im about to order some dayton 8' references
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
