Four 18" Cerwin Vega Strokers. Help!!!
Phazer131
just throwing around numbers here but an idea of torres calc
R.I.P!
(Nov-29-2009)
92 explorer
current build
port area is more related to box size not amount of subs for slot ports you want roughly 13-16^2 of port per cube of box
and for aero ports its something like 9-12 but i could be wrong i dont use aeros often
but listen to basslova and download torres box calc it makes things soo much easier
13-16? hold on now buddy, 9-17cu.in^2 is fine. just depends on the application.
Hey buddy, if you can get me the T/S specs of one of the subs, i can tell you the ideal airspace and tuning frequency for those drivers.
Free air resonance 31hz
Total Q 0.191
Mechanical Q 7.923
Electrical Q 0.196
Comp.Vol 5.78 cubic feet
Max Excursion 1.5"
Voice Coil Resistance 1.7 ohms per coil
Vol. Displacement .43 cubic feet
Those are the values I have for the stroker 18d2. I have 4 in total and would like to make two separate boxes with two subs in each. Im hoping to make each box 24x48x24 that will fit pretty well.
I just wanna know what power and what are they going in
I have two t20001bds (for now) and they are going on the bed of my f150.
in a blow through or just in the back of your bed??
R.I.P!
(Nov-29-2009)
92 explorer
current build
Just the back of my bed. Ive treated entire bed with fatmat and purchased a shell .
this sounds like a blow thru...
called it
and if anything take the rear window out and build a wall in the bed and put a camper top (wrong name im sure) on
you can always put the rear window back in later on
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   1 Member, 0 Anonymous, 1727 Guests (See full list)
