I will most likely have to buy the slick sand off the net and use that next time. I will sand everything down again and make sure everything is as smooth as a babies ass. But for the time being this should do the trick.
2006 SPLMAX Bass Race Competitor of the Year
2006 Bass Race 156 points
Team DC Sounds
Team Maxxsonics
Team HR
Team Second Skin
Team Hooker Audio
http://dcsoundlab.com/
2008 Starting from scratch
Just thought i would give you a couple ideas on some clear coat paints for when you want to go this route.
I will also grab info about spray can filler primers here soon also.
I need to add both to my Painting Plastic Thread.
The trick is finding a good aerosol clear if you don't have a paint gun and compressor set up.
If you must use a spray can clear, and I do sometimes, here are 2 that I use and work good. And when they are cured, you can wet sand them just fine.
Posted Image
It is a 1k clear. Meaning it is 1 part. Fan pattern spray and lays on thick.
Posted Image
It is an Alsa spary can. They fill it with whatever you want. They offer it in 1k and 2k. 2k means it has a hardener. You push a button on the bottom, it punctures the hardener inside, shake it up, and spray it. You only have 1 use, but it is great. pricy though.
Neat thing is they offer ALL KINDS of paint in this can.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
