power acoustic amps
ROAD_DOG
the audiopipe seems to be a good amp
if you really cant wait for a sundown or a better amp and would like a cheaper alternative to hold you over, i would say audiopipe is your best best. or look around for a used amp
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
from what I been hearing is that the hifonics amps will work good then take a dump they just burn up supposedly they are known for being crispy critters
if u dont know what your doing. gotta keep your volts up. they ae power hungry. supportively does rated at 14.4. the brutus at least. i had a hifonics amp while back and it did me good. no problems
I never owned a hifonics amp before so i wouldnt know about keeping the volts up just how may i be able to do that
just make sure u got the big 3 going on or ho alt and couple batteries depending on how much power u want to run.
im looking into all amps but since i want to get my system up and running im considering a good cheap amp that will do good till i get a better amp
I dont plan to go big just the regular subs and amp and a 4 channel amp later down the road for my speakers I dont plan on doing the big 3 on my car since im gonna be selling it soon
How much power do u plan on running? Big three is recommended if your demand for large amount of current from your alternator is a must.
im just planning to run 2 dc audio level 3 subs with a good amp 1200 watts amp to push them the big3 i dont want to do to my current car becuase ill be selling it soon
With than then a good batt in front and back and u should be fine but your gonna strain that alt
how would I connect a second batt in the trunk postive from front batt to the positive on second batt in the trunk and the negative to grounded bolt
  • Who's Online   1 Member, 0 Anonymous, 702 Guests (See full list)
