is a soundstream 6500d good enough to push fi btl n2 15s
slamin87
a buddy saling me his soundstream 6500 and i was wondering if it will pound the shyt out of two fi btls or 2 orion hcca 15s debating on subs it will be at 1 ohm and just to say the subs where in the perfect box and i got more then enough electrical for the amp 4 bt100s will these setups hit in the 150s thats what im aiming for it is a 98 deville and i will be sealing off the truck from the cab
Ugh, if you really want a 50 just tune near your car's peak and throw the power at your subs
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Ugh, if you really want a 50 just tune near your car's peak and throw the power at your subs..if you want a daily groundpounder...a 50 is gonna be tougher
Build in Progress
def want it daily bro and hiting lows like hell
Then tune low, numbers aren't all that important if that's what you want..a 145 @35 hz is a lot more impressive than a 150@ 55
Build in Progress
def true shyt my 2 ten orion hccas did a 145 on a audiopipe 3000d d tuned to 38 hertz. but the reason why im upgrading is for that 150 mark just to say i can hit it daily
IMO those amps aren't fit to anchor a boat with. They make shitty power @ 12v, go really weird if you drop the voltage below about 12.5v, and the machining on the heatsink will slice the hell out of your hands which to me is the icing on the crap-cake.
But that's just me.
10.x volts fo' life!
my ss 4K it´s pretty nice for daily, takes ton of abuse but i´m with Boon on this one, this amps aren´t that strong unless you have great voltage for them, only reason i have a 4K laying around it´s because i bought for 350$ :)
