The reason why i put them like that is because they matched up perfectly DD subs are 500 rms and i can get 1000 watts out of the DD amp and its "perfect" and the AQ subs are 600 rms and amp is 1200 watts but if i went with the DD subs and AQ amp i would be over powering by 200rms total. Is being over by 200 bad?
200watts over powered is nothing...
Theres been people to put 2000+ watts on a 1500 series woofer. Its all about your box, and having CLEAN UNCLIPPED POWER.
Besides that the impedance of a woofer is a varibul and is never 1 ohm or 2 ohm or whatever ohm like they say.. The impedance of a woofer is only true to the specs when the woofer is not playing, when the woofer is playing you have other things that come into play like box/impedance rise.
So your sub amp maybe wired down to 1 ohm, but when the woofers are moving, the amp will be playing well above the wired impedance which gives you less power then the amplifier that is rated with a dummy load that is not a variable impedance.
By the time your said and done, over half the rated power of your amp is lost due to impedance rise, heat, voltage drop, etc.
I dont know the pricing of the dd products (I'm going to be calling tomorrow) but im assuming their amps are more exspensive?
Digital Designs is going to be signifigantly more expensive then the AQ woofers because everything about dd is made and assembled in the USA.
While Audio Que parts (motors, cones, etc) come from China, and assembled, stored, and shipped from the DD unless that was changed.
Okay thank you for the detailed response. That makes a lot more sense to me now! :drinks:
Thats good to hear some what. I like the fact they are made in the U.S.
I had a Cadence C6 for 3 1510´s and they took it like a champ, i had 900 clamped watts per sub for about a year and pounding the system around 3 or 4 hours DAILY since we don´t have rules against car audio over here hehe.
What i can tell you is this, i don´t have any experience with AQ subs, but that sub looks just like my 2512´s man, besides that, i have the understanding that AQ and DD are the same, am i wrong? would like some one to jump in here with an opinion, but if i´m correct, i would say the AQ should be louder than the DD 1512 :peepwall:
Once again, these are only assumptions, what would i know? :pardon:
Yeah ive been told something like that too that they are like run in the same family or something. I think i may be going with DD subs and an AQ amp.
I know a little bit more about this matter but i prefer not to tell because of personal reasons, but, you can see the AQ1200 , 2200 and 3500 and compare them to the M1 , M2 and M4 and make your conclusions...
Thats fine, i understand.
  • Who's Online   0 Members, 0 Anonymous, 4880 Guests (See full list)
