Question about KnuKonceptz In Line Fuse Holder
i got a KnuKonceptz High Current In-Line Fuse Holder.
and there is place to put 3 MANL fuses in it.
If i want to fuse my 0/1 cable with 300A fuse does it means that i
have to put two 120A fuses and 1 80A fuse ?
Anther question how can i fit a KnuKonceptz Battery Terminal to Xs power D5100 battery ?
Hertz HSK 165XL
Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
No, you need to use 3 fuses of the same amperage. So if you want 300amps of fusing, you need 3 100 amp fuses. As for your 2nd question, you would need to purchase some posts to install on the battery, then you can install the Battery Terminals.
97 Maxima SE
Bunch of shit going in, check out the build
I second this.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
the battery terminal isnt needed just put ring terminals on the end of the wire and screw then straight to the battery if that isnt an option you would need an adapter
as for the fuse holder why not get the fuse holder that has one 300a ANL fuse
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Why is that i need to install 3 of the same fuses ?
cuz the current going to the least resistance ? and the 80A wont be effective ?
Cuz i already got it and what the problem to put 3 fuses ?
Which adapter ? from xs power for the battery site there are couple adapters ?
Hertz HSK 165XL
The fuses are wired in parallel in that fuse holder. So all current will be split evenly between the 3 fuses. Since the smallest fuse (the weakest link) is 80amps, you will probably end up blowing up that fuse when the current reaches 240amps (Eighty x 3)through the fuse holder. Now you are down to the 2 120amp fuses. So if you want that fuse holder to be able to handle 300amps of current, do yourself a favor and get 100amp fuses. They are $6.49 for a 5 pack from knukonceptz here: http://www.knukonceptz.com/productDetail.cfm?prodID=MANL5-100A
As for the adapters, you have to look at their site to see which one is for your battery. A phone call to a dealer like Mechman will probably get you an answer too.
97 Maxima SE
  • Who's Online   0 Members, 0 Anonymous, 1350 Guests (See full list)
