In a semi compact situation how small of enclosure could a person go with for the sa-15's? Woofers would have d1 spl coils and enclosure would be tuned to 35hz.... audioque 2200d(or 2) on the pair of woofers...would 2.5 net per woofer be too small?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
3 cuft net is the smallest
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
what problems would i be looking at if i were to go smaller? cooling?
3 Kinetik Hc2000's
Dual 200amp alts.
i thought the sa series were designed to be able to put in small boxes if needed. I'd think that 2.5 would be fine with that amount of power long as it's clean.
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Kinda what I was thinking, I can do 2.8 with no problem, but 3 is going to be pushing it... I have gobs of power to throw at them so I'm thinking it will be alright... I could see cooling how cooling would start to be an issue if I go to too small but the aluminum coils and newer style cooling ring should help make up for it
3 Kinetik Hc2000's
Dual 200amp alts.
I could be wrong but I think it 3-3.5 for the SA 15. But smaller boxes increase the power handle(not that it needs it)by limiting the sub movement. Sound wise it produces a punches bass. And don't look that deep low note. JMO
1993 Mazda Mx-3
^^X2... had mine in 5.4cube net. The only thing I hate about it is that there is no room for my amp. If you can stretch it near the 6 net, that'll be much better.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
i appreciate the advice guys, i can get it pretty close to 6cuft net for the 2 but im trying to conserve some room to mount my amps...
3 Kinetik Hc2000's
Dual 200amp alts.
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
