I put an amp in my buddys 95 ford escort and right after that it started blowing his running light fuse! eery time we put a fuse in and flip the switch the lights come on for a split second then the fuse blows every time. We are getting good voltage at the fuse box at 11.93 volts. Please reply if you can help. Thanks
Bad ground?
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
how is 11.93v good?
car off maybe?
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
car off voltage should be higher than that . un hook the amp see if it still does it. what factory wiring did you touch.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
where did you route your wiring from and what wire did you tap the remote lead into you've created a short somewhere.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I tapped into the key on wire. The stereo and amp turned on and off approprietly and worked fine the running lights just wouldn't work.
