I'm going to building a t-line box for a REX12 to go in my room. I was wondering what would be the best way to build the box (mostly worried about port placement here.) I wasn't sure if it would be better to have the port up or forward.
I made a quick picture for my ideas for the box.
As you can see, I kept the subs at the bottom, because I've always learned they're supposed to be down low.
Which of these is better? Or would you recommend a better design? I'm open to suggestions.
If it matters at all, my room is about 12x12
Edited by LZTYBRN
Put 45s in it. And I feel like the 2nd one is a more common design, but Im not big in the t line scene
Edited by Tek
definitely the second option and with 45's it should be nice and good.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
I think you will have a better bass responce with your T-Line, with the port facing the wall directly. From the bottom, or middle, or top, I believe the output will be the same as far as DB's but where the bass goes will change. Id Recommend A tuning of like 28Hz and let it hit out the port right against the wall like 1ft away or less. It will reverb the best that way. Dig the Idea. Im gonna do teh same with a TC Sounds Epic 12" just gotta sell me stuff. lol
2003 Dodge Intrepid 3.4L v6 Stock Alternator 12.5 V all day.
DREAM SYSTEM IN PROGRESS> STILL JUST A PLAN....
(2) Custom Ascendant Audio Mayhem 15's 6th order walled
(1) (4)JL Audio 1000/1 V2
(4) JL Audio 500.4
(5) XS Power D3100 (1) XS Power D1200
(1) Mechman Alternator 400+ AMPs
(8)Tang Band W8-1772 8" Neo Drivers
(8)Tang Band 25-1166SJ 1" Neodymium Tweeters(2) in each pillar
(4) Dayton PS180 6.5" Neo Full Range Drivers in Rear Shelf
(4) Eminence Delta Pro-8A 8" Midrange
Really with a room 12x12 its more of were the box is placed then the port.. Personaly id make the sub downfire with port forward.
Edit: oh and toss it in a corner farthest from were you sit
Edited by 94retta(219)
Yes. Yes I guess that could be true.
(4) JL Audio 500.4
Another option would be to put the sub faceing up, port forward. The reason im saying face it up or down is to help out with the bass being extreamly un even in the room because the room is a perfect square.
DUDE THAT NEWTSNS 10" IS OF THA MUTHA FRIKIN HOOOK! OMG!!!!!!
(4) JL Audio 500.4
  • Who's Online   0 Members, 0 Anonymous, 973 Guests (See full list)
