Who Makes An Amp That Is .5 Ohm Stable?
zaxfire69
in fact with a dual 2ohms...you can have 1ohm(parallel wiring) or 4ohms(serie wiring)
so the solution with your two BL are 0,5ohm , 2ohms orrrrrrrrrrrrrrrrrrrrrrrrrrrrrr 8ohms :lol:
to have 2ohms with your two BL ..... each BL wiring parallel (1ohm each BL) and wiring the two BL serie...
sorry for my poooooooooooorrrr english :blush:
Mercedes CLK Kompressor
Alpine CDE 9881 RB
Digital Designs Z1 <--------------fuc@@@@ng amp :(
15" Fi audio Btl full loaded
3.7 cuft @ 33hz with 50 square port
Northstar NSB 90
all 1/0 power and ground
well i say 2ohm because its probablt going to be less of a drain to run a 2ohm load then it is a half ohm load
yep 2ohms seems to be the best choice ;)
Alpine CDE 9881 RB
Northstar NSB 90
Where is an Old School Us Amp when you need one...The ones that would put out huge amounts at 2 ohms... Oh Assman has the amps I need...I could use that 2000x..2 x 1000w @ 2 ohms....
Edited by zaxfire69
Hifonics Colossus
1600watts x 2 @ 1ohm
3200watts x 1 @ 2ohm
$688 shipped from Sonic Electronix
http://cgi.ebay.com/HIFONICS-XXV-COLOSSUS-...1QQcmdZViewItem
I'm running a pair of RF T1Ks on my Bls. You can get a pair of them from HDA for $307 shipped each.
http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER...1QQcmdZViewItem
Edited by Derrick824
Guest MegaloManiac
Well I am purchasing another Dual 2 ohm BL 15 and I am going to run .5 ohms..What other wiring options do I have??
wire them in Series-Parallel
each sub wire in series to get a 4ohm load then wire them together into parallel to get 2ohms
  • Who's Online   0 Members, 0 Anonymous, 1428 Guests (See full list)
