Thanks for the compliments.
When I checked to make sure everything was square, it wasnt. You can see the gap at the bottom of the square. So I threw it away and cut new pieces.
I cut these pieces big so they can trimmed and rounded
Flush bit for the router squared everything really nicely
3/4" round over bit to take the edge off, just a little bit of sanding and it should be nice
This one is nice and square
Port walls sanded and looking better
Port flange tomorrow
Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier
Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
just looked through all 6 pages, had me hooked on when i saw the amps you were using. That the second biggest t2500 ive seen, the only 1 ive seen that puts out more does 3430x1 @ 1ohm
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thanks bro!! Lots more to come I hope.
Rounded the inside of the port opening
Rounded the outside of the port flange
First cut for the speaker baffles
Went to home depot tonight and priced some wood for the rest of the box. I'm really leaning towards birch over mdf for the rest of it. The weight difference was really impressive, plus the birch was only 10.00 more
