Going from class AB to D for sub amp- worth it?
Class Ds should be more efficient, but ABs have the ability to be cleaner.
surprised no one else mentioned A/B amps put out a cleaner signal
my specific reason for this post ...
Not to me, I will never switch to a class d.
I will Always run Linear Power Class A/B amps ...
sorry for not going into details ...
sigh, folks. AB amplifiers are less efficient (my RF 200a4 is ~50%), yet they output a much cleaner signal. D amplifiers are much more efficient (70-90%) yet the signal isnt as clean. thats why people generally use Class AB amps for mids and highs and class d subwoofer amps. its harder to hear the unclean signal through subwoofers as opposed to mids and highs.
edit: uhoh made a good point. those SQ guys use AB/A amps in their setups to get rid of as much distortion as possible.
Edited by Kranny
i understand completely what you meant and why you said it
for the noobs
most high end audio use A/B amps for there subs
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1316 Guests (See full list)
