I'm using an archaic Alpine 3539 bridged to my RF Stage 3 sub, which works well but really taxes my electrical system.
Wondering if a newer Alpine/RF class D amp which are more efficient would work the electrical less while producing the same power?
doing so would also allow me to ditch my POS x-over and use an internal one in the new sub amp, making things simple, the way I like them.
TIA!
-Audio
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
Correct. Go for the class D.
Eclipse cd7000
D classes are more efficient than other classes -> you get more power with less taxation on your electrical. so yes go with the D class
Not to me, I will never switch to a class d.
I will Always run Linear Power Class A/B amps ...
Class D amps are always more efficient. You're A/B amps are gonna pull more on the electrical to get the same power...always go with the class D's.
D all the way, tend to last longer from what I've seen and heard as well
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
I seen 10 Class D amps burn up at 2010 USACI world Finals last year ... You shure your info is correct ??
Class Ds should be more efficient, but ABs have the ability to be cleaner.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
surprised no one else mentioned A/B amps put out a cleaner signal
R.I.P!
(Nov-29-2009)
92 explorer
current build
^^lol same here. Then again, how many people care about SQ? :/
LMFAO so true
:blush:
