I don't think it's the belt, belt slipping doesn't cause flickering of the vehicles electrical.
Edited by sprkn_ranger
I agree for sure his problem is deeper than that.
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
Maybe check the wire goin from your battery into the fuse box and the main engine ground. And how is the voyage before you get flickering?
Before anything happened my original pos battery cable went out and my car didn't start up I then ran 0 gauge from pos alt to post batt then it did startcould that be the problem? I recently fuse that 0 gauge too? Thanks for the help guys I'm really appreciating it.
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
As in the original positive battery cable the one that's connected to terminal of the pos battery I assumed burnt or something because my car didn't start but when I added the extra wire from positive alt to positive battery my car runs and if I were to take the 0 gauge wire off the car will not start. Sorry if it doesn't makes sense it kind of hard to explain.
Edited by StreetSlappah
Build Log
17" gold bbs
JVC dvd double din
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
Ok, well it sounds like you have a bad connection somewhere. have you replaced the main pos wire? And where does it go? The fuse box?
Yea the main pos wire went out and the only thing connecting the pos batt to alt is the wire from the big three
Build Log
17" gold bbs
JVC dvd double din
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
Well if the main wire burnt, then you need to replace it, but first find out why it burnt, it may have been rubbing on something and shorted out, and you definitely want to fix that problem before you replace the wire.
Thanks bro deffitenly gotta check that out its just going to suck trying to find where it shortened.
Build Log
17" gold bbs
JVC dvd double din
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
No prob! And the easiest way to know if it shorted is to pull the wire out and look at it, and if it did short somewhere then it will be black and charred in the area it shorted in. Plus the jacket will be torn exposing the copper wire inside. If the wire looks fine just replace it and see if that works. And also check ALL of your fuses cause they tend to blow when wires short or have bad connections.
  • Who's Online   1 Member, 0 Anonymous, 1343 Guests (See full list)
