Hey, I'm kinda new to the site and not new to audio but it stomps me when i get to the Ohm part.
I have American Bass XO's and I want to bridge them but everytime I do it cancels itself out and comes in and out. The way I have it wired is positive on both sides of one sub (and negative) and I have them together and They lead out to 1 positive and 1 negative as a normal speaker of course and same with the other.
Specs:
BRAND NEW 12" AMERICAN BASS XO1244 DUAL 4 OHM VC 600 WATTS XO12 SUBWOOFER
DUAL 4OHM VOICE COILS
OVERSIZED, DOUBLE STITCHED BUTYL RUBBER SURROUND
4 LAYER HI TEMP VOICE COIL
HEAT PUMP - INTERCOOLED MOTOR SYSTEM
JET BLACK CARBON MICA INJECTION MOLDED CONE
RDC 1.5
LEVC(MH) 1.439
FO(Hz) 32
SD(msqM) 47.14
BLTM 6.793
QMS 2.848
QES 0.881
QTS 0.673
n(%) 0.269
SPL(Db) 93
VAS(L) 53.7
CMS(Um/n) 170.2
MMS(g) 125.1
VC 2
MAGNET(OZ) 50
XMAX(+/-mm) 10
POWER(RMS) 300
POWER(MAX) 600
F RANGE(Hz) <500
MAGNET DEPTH(MM) 152
MAGNET DEPTH(INCH) 6
Wait what, you can't bridge subs.
You either have them wired in series or parallel.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
That's a parallel wiring configuration, giving you a nominal load of 2-ohms.
When you say "bridge," that is just a certain way to wire your subwoofer stage to your amplifier, it has nothing to do directly with your wiring configuration.
BUT, as a guess, your amplifier is only 4-ohm stable bridged, so when you wire down to 2-ohms, your amplifier is cutting in and out of protect trying to prevent you from frying anything... :/
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
o ok, I had a rockford fosgate 400-4 and i tried to bridge on that and it still cut out
are you trying to run the subs in parallel AND bridge the amp? because no wonder it went into protect, because each channel is seeing 1 ohm and the lowest it can handle is 2 ohms (in stereo, 4 ohms bridged).
  • Who's Online   0 Members, 0 Anonymous, 2413 Guests (See full list)
