cal Posted March 10, 2011 Report Posted March 10, 2011 i need some help i have a 2006 dodge caravan 3.3 it has a 160 amp alternator but i need to upgrade due to my recent amp purchase it is 2000 wrms i already bought a new kinetik hc 2000 not yet installed and was wondering i can get a rewound 250 amp alt between 350 and 500 depending on the company but is it cheapper to add second alt?
Tek Posted March 10, 2011 Report Posted March 10, 2011 Adding a second alt is a lot more I believe, assuming you buy a bracket as opposed to making one
Loudcivic Posted March 10, 2011 Report Posted March 10, 2011 160 amp alt with a couple nice batteries will be just fine. try it with what you have now and see wut your voltage is at. you said you dont even have the hc2000 in so how do you know your gonna need a bigger alt? 2015 silverado crew cab nothing atm but soon...
StreetSlappah Posted March 10, 2011 Report Posted March 10, 2011 You can easily run that 2k amp with your stock 160 amp alt and that's kinetik battery just run two runs of 0 gauge to the back and big 3. Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center] Build Log http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/ 2005 subi STi 380whp 355whp 17" gold bbs 5% tint all around w/sunglare strip JVC dvd double din Knuconceptz 4ga wiring XS Power! Big 3 8" SAv2 d2 1800 audiopipe
cal Posted March 10, 2011 Author Report Posted March 10, 2011 160 amp alt with a couple nice batteries will be just fine. try it with what you have now and see wut your voltage is at. you said you dont even have the hc2000 in so how do you know your gonna need a bigger alt? i only have 1 hc 2000 and the factory battery i dont have anything installed yet the amp is also in the box the 160 amp is just a factory alternator im trying to get everything together before i do the install the reason im looking at the upgrade in alt becasue of the current draw from the amp. do you think i can get away with factory 160 amp?
cal Posted March 10, 2011 Author Report Posted March 10, 2011 You can easily run that 2k amp with your stock 160 amp alt and that's kinetik battery just run two runs of 0 gauge to the back and big 3. ok maybe ill try it first i was concerned for the amp. but why would i need 2 runs of cable to the back are you saying to use 1 for power and the other for ground?
