Slight humming or buzzing on my speakers
I got my RF T1 series comps in and there Is a buzzing or humming noise that comes from the speakers when i plug the rca's into my 4 channel amp. I thought it may be the grounds from both amps grounded to the same battery ground so i moved the 4 channel ground to the chassis and it went down some but its still faintly there. I moved the rcas so they werent near power and still there. Any ideas guys? Im using a 4 channel LOC to go to both amps
-----SELLING EVERYTHING----
2 DC sound labs 3.5k's (still avail)
2 HDC312A D1's (still avail)
5 XS Power Batteries (1 d3400 and 1 d1200 left)
4 runs of knukoncepz 0 gauge (have all the wire still)
DC power 270XP alt (sold)
RF T1 6.5 components (both sold)
Powerbass XAX 4160 (still avail)
Custom built box 4.75^3 tuned 34hz (still avail)
Try grounding your rca's to your head unit chassis. Like this.
edit: add picture
Edited by Bocaj333
Car
1991 Honda Accord EX
System I now have and is finally installed!
Pioneer DEH-P7200HD
Digital Designs 3512
Digtal Designs CS 6.5" components
Audioque 2200
DD Audio C5b
Optima Yellow Top
Rockford Fosgate 1/0
Damplifier Pro
Luxury Liner Pro
edit: add picture
How do i do that, my rcas go from my line out put converter, which is in the trunk 2 fert from my amp, straight to the amp, how would i ground them there? Also what did you cut the plug off and just ground the wire?
Also when i dosconnect the rcas from the amp the buzzing goes away...do i need a ground loop isolater? How would i know if i need one or not? Ideas anybody
touch your RCA metal while it's plugged in with your finger and see if the humming still happens
Ok ill try that. And what happens if it goes away, whats that mean?
What LOC did you use?
Its a david navone engineering 4 channel loc. It works pretty good, but i think i may have wired it wrong, what i did when i wired it is combined the front and rear left channels together and the front and rear right channels together, do you think that could cause the noise?
  • 3 weeks later...
im interested to find out how to solve this problem as i also have the humming problem with my speakers
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
Well i never figured it out so im going to just run all new wire for my speakers and even the amp and see what happens
  • Who's Online   0 Members, 0 Anonymous, 768 Guests (See full list)
