I'm planning on fitting 6 10" subs in my car (each at 4Ω) wired up to 3 2-channel amps (also each at 4Ω). My head unit only has 1 pair of RCA outlet.
So how on earth do I split the RCA and how do I wire this stuff up?
Where I come from we have a saying: Bass moet je niet horen, die moet je voelen.
It Means: You shouldn't hear bass, you should feel it.
6 10s? how lol but anyway you would want monoblock amps much more efficient at producing bass.
Edited by Carroot1
You have indeed exposed your newbieness. If you have to ask something like this then putting 6 10's in a car is probably not a good starting point.
Do you have the subs?
Do you have the amps?
If you're going to do something like that, you should probably invest in a head unit with an actual subwoofer channel.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
On my last build I had 4 12" subs hooked up to a 4-channel amp. Sounded great, felt even better! (I loved all the complaints from the neighbors.) That was in my last car. Now I have a smaller car with less build space. I think I got the wiring covered, just cracking my head about splitting the RCA...
Subs and amps are on the way, HU is an old one I had lying around.
Finding a decent HU with a sub channel is pretty hard here in Belgium. I have to go to Germany half the time...
About using 10"... Yeah, I'm trying to make something that looks, sounds and feels great and I've never used 10" subs. I custom make cases for friends and i'm always trying new stuff.
Do the amps not have RCA in and out I assume?
Big 3 with Yellow Top
You, my friend, are fucking genius! yahoo.gifI totally forgot about the RCA outs. Problem solved! clapping.gif
Using a ten inch sub is not what I'm referring to. Why would you use 6 10 inch subs?
I'm surprised no one else has anything to say here...
