I'm planning on fitting 6 10" subs in my car (each at 4Ω) wired up to 3 2-channel amps (also each at 4Ω). My head unit only has 1 pair of RCA outlet.
So how on earth do I split the RCA and how do I wire this stuff up?
Where I come from we have a saying: Bass moet je niet horen, die moet je voelen.
It Means: You shouldn't hear bass, you should feel it.
You have indeed exposed your newbieness. If you have to ask something like this then putting 6 10's in a car is probably not a good starting point.
Do you have the subs?
Do you have the amps?
If you're going to do something like that, you should probably invest in a head unit with an actual subwoofer channel.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
On my last build I had 4 12" subs hooked up to a 4-channel amp. Sounded great, felt even better! (I loved all the complaints from the neighbors.) That was in my last car. Now I have a smaller car with less build space. I think I got the wiring covered, just cracking my head about splitting the RCA...
Subs and amps are on the way, HU is an old one I had lying around.
Finding a decent HU with a sub channel is pretty hard here in Belgium. I have to go to Germany half the time...
About using 10"... Yeah, I'm trying to make something that looks, sounds and feels great and I've never used 10" subs. I custom make cases for friends and i'm always trying new stuff.
Do the amps not have RCA in and out I assume?
Big 3 with Yellow Top
You, my friend, are fucking genius! yahoo.gifI totally forgot about the RCA outs. Problem solved! clapping.gif
Using a ten inch sub is not what I'm referring to. Why would you use 6 10 inch subs?
I'm surprised no one else has anything to say here...
  • Who's Online   1 Member, 0 Anonymous, 1207 Guests (See full list)
