1.34 Ohms
JLaudionut
Ok guys i have 3 jl w3 10"s dual 2 ohm voice coil woofers which im planning on powering by a Cadence TXA-1000d which is rated at 1000 watts Rms @1 ohm
using rockford fosgates woofer wizard i figured out how to wire the subs to 1.34 ohm load. My question is will the 1.34 ohm load damage my amp? i mean i am reletivlely new to car audio and this might sound retarded to u experts here but i just don't want to fry my amp. thanks ahead of time for the input
1997 Dodge Ram 1500 extended cab
Build in progress... pics to come
pioneer deh-6700mp
Lightning Audio Bolt 6x9 3 ways
Memphis prcs 5 1/4 components
Cadence TXA-1000d amp
2x JLw3-10's dual 2 ohm... wired to 2 ohms
Wired by-0 gauge and 4 gauge
It will be fine. You may not get the 1000wrms power tho since you will be running the amp at 1.34 ohms.
What does your amp produce at 2 ohms? you for sure will get the rms wattage produced at 2 ohms, and a bit more. Im guess around 920+wrms at 1.34 ohms.
The lower the ohm the amp is ran at the more power/watts the amp will produce. Most amps are not stable below 1 ohm tho, but you dont have to worry about that.
its only 650 watts rms @2 ohms ... thats what i thought but i wanted to be safe. Much appreciated man!
pioneer deh-6700mp
  • Who's Online   0 Members, 0 Anonymous, 881 Guests (See full list)
