i think the amp is too strong for just 2. it is a power acoustik bamf5500, which i know doesn't push what it is says it does, 3200rms@1ohm, but i blew one sub, got new one and amp was trying to blow that one too.
Why not go with 2? And use a ported box.
What subs are you using? Did you set gains with an oscope? May be clipping.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
that amp isnt "too strong". its like a 2000rms amplifier and you'll be lucky if you even reach that power output from that amp.
you arent overpowering your woofers. you're clipping them to death, thats why they keep blowing. your amp isnt as strong as you think it is. its all user error.
edit: i dont know where you get the 3000rms rating from the subwoofers. it clearly states 3000 peak (which means nothing) and 1700rms.
i dont even know how you'll wire 2 of the subwoofers to the amp because theyre dual 2 and the amp is 1 ohm stable. you can either wire to .5 or 2 ohms and i sure as shit know that amp wont survive at .5 ohms.
Edited by Kranny
i'm using power acoustik mofo152X 2 ohm dual voice coil. don't have an oscope, and wouldn't know how to use one. can tell you that i had bass boost all the way down and gain at about 1/3 up. rated at 3000max 1700rms
i know the amp isn't pushing what it's rated, i already said that. but if my boost is all the way down, gain at 1/3, how can i be clipping them?
you clearly aren't reading what i'm writing since i NEVER said the subs were 3000rms. before you try to make me look stupid, read whats written
oh really?
they are power acoustik mofo 152X, 3000rms.
what the hell does it say there? dont even try to make ME look like the dumbass, i read it twice over to make sure that what im saying is correct and not falsified.
Edited by Kranny
gain at 1/3 means absolutely nothing. and it could be anything. you playing clipped songs, clipping your headunit by using some setting on it, volume too high, voltage drop leads to clipping as well.
  • Who's Online   0 Members, 0 Anonymous, 1788 Guests (See full list)
