:popcorn: the reason the 2 15s sounded better than the 3 is because you have 3 big subwoofers that want to move a lot of air, the 3 15s in the trunk are cramped and have no air to move, plus the 2 in one box and 1 in a single, the 3 subs probably don't all have the same air space per sub so they are not firing simultaneously causing air turbulence and the subs are canceling, you would probably sound better if you made a good ported box and ran 2 of them underpowered at 2ohms with all gains and settings set correctly Edited by michigancapri92
my bad, i said the wrong thing at the top of the page, but if you look at #15, which is about where you came in the conversation by the way, i clearly say the correst ratings. 3000max, 1700rms. so, a misunderstanding on both our parts. but, back to the topic at hand. i don't really turn my stereo volume more than half way. i believe i have it set correctly. it's a pioneer deh-p6800mp.
i know the amp isn't pushing what it's rated, i already said that. but if my boost is all the way down, gain at 1/3, how can i be clipping them?
gain at 1/3 means absolutely nothing. and it could be anything. you playing clipped songs, clipping your headunit by using some setting on it, volume too high, voltage drop leads to clipping as well.
do you have any bass boosting features enabled on your headunit? ideally to tune gains you must have your entire equalizer set on 0 or off or flat. there should be absolutely no reason for your subwoofers to blow unless there are wrong settings somewhere.
could you direct me to a person who can design it? i can build myself, just need help on the design aspect.
there is a bass boost set on. loud is on high, sla on +4, low pass on 50hz, high pass on 125hz
ram design is a good person to ask, you can try doodling with torres tuning calculator and see what you can come up with yourself and then post it upand get help from there, best way to learn is to try as much as you can yourself and have your wrongs corrected
i just sent him a custom design request through his new website. i've tried the torres calculator, but don't really know what i'm doing on it with a ported enclosure. thanks for the advice about the airspace, i'm about to go out and remove one of the 15's and re-wire the others to 2ohms and see what that does for me.
umm theres your problem. turn all that shit to off and 0. that is why you are blowing your woofers up. also, put your low pass to like 80hz.
gonna try that after i get this 3rd out. also what about the amp settings? what should i have those at?
  • Who's Online   0 Members, 0 Anonymous, 1788 Guests (See full list)
