Quick question...Are the front and rear RCA outputs of a head unit going to put out the same signals, as long as you don't touch the fader?
Reason I ask is, I'm thinking it will be a lot cheaper to use one amp for the whole car, rather than one for the front and one for the back. (or two amps instead of three or four)
Edited by LZTYBRN
If you have a 4 channel amp it has 4 inputs so that's enough for the front and rear outputs from the deck.
Edited by bumonskateboard6
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
I'm going to have mids and highs on separate channels, so it's not enough. And that's not what I was asking...Just want to know if the front output from the H/U is the same signal as the rear output. Am I correct in my assumption that they're the same signals as long as you don't mess with the fader?
unless your head unit offers 4.1 digital processing it's 2.1 or stereo...front and rear will be the same signal
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
they will output the same voltage. what do you mean you will have mids and highs on separate channels? do you mean one speaker per channel? and also, what "isnt enough"?
Sweet thanks.
I will be having 2-4 speakers per channel. When I said it wasn't enough, I was referring to when bumonskateboard said that 4 channels will be enough to run all front and back speakers.
