i have a family member that there suburban wont start. the first problem was the truck wouldn't start. someone replaced the ignition relay and it started then after it wouldn't start. then another guy removed the factory alarm and replaced the ignition harness and now it wont start the ignition relay clicks when fuel pump first starts and stops and the start relay clicks when you try cranking it but dont start. can some please help if they know what can be wrong?
what year truck? its probably the security system. but it also sounds like the starter is stuck. replace the starter relay first, if not its probably the starter itself. you can test this by tapping on it with a hammer. not smash on it but tap to try to break it loose. if noting it could be 100% dead.
