It could be tricky to get the extra volume in the bed to not be too restricted at the cut through point.
This. I'd not recommend doing a box like that...just too risky depending on how small the cut-through is going to be compared to the normal size of the box.
Yeah I agree with both of you it is risky. The cut through is going to have to be huge to compensate for the short height of the bed. I would be using every inch I can squeeze out of it leaving enough room to glass and attach to the body...
Unless I can spec out a good 4th order BP in {16" X 39" X 60"} which will be tight with the 15.5 dia of the sub. I may be able to shave a bit off by removing the gasket though...and notch out a section in the top and bottom of the box.
I would think that you're probably best off with a bp, the angle probably wouldn't matter really, it should be fine :-)
How big is the hole you are going to cut be? I have a nice idea for how to do the box.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Hole can be as big as it needs to be. Just to guesstimate a max...36" X 14" ...ish
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
