wiring 1 dual 4 to a 4 channel
my friend wants me to hook up his system. he has a dual 4 15" type r and hes gonna be running it on an alpine mrv f 407 amp. how would i wire it up to a 2 ohm load on the amp?
Not sure if this would work on a 4channel amp, someone correct me if I'm wrong.
if its a dual 4 just wire in parallel and you will see a 2 ohm load. :drinks:
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
If you wanted to utilize all channels, you would wire one coil bridged to one pair of outputs (usually channels 1&2 although it may be 1&3) and the other coil bridged to the other pair of outputs. This will give you a 2 ohm load per channel. If you do this, make sure to gain match as accurately as possible, and make sure the amp can handle 2 ohms per channel.
Guys, you can't treat a 4 channel amp like a 2 channel or a monoblock. If he wants to utilize all 4 channels, he can't wire the coils in parallel. This will only allow him to use 2 channels (or all 4 at 1 ohm, but that's no good)
how would i do this?
If the amp is bridgeable, then it would effectively be a two channel with each channel at four ohms. If that is the case then if he gain matches the two outputs he will be able to safely wire it that way.
Yea Reall you and I are talking about the same thing, I was talking to the 2 replies right before my first reply saying just wire the coils together so you got 1 positive and 1 negative. That wouldn't work in his application.
Lgz, read my first reply (reply #4 in this thread) to see how you would do it.
  • Who's Online   0 Members, 0 Anonymous, 4436 Guests (See full list)
