yeah and it would look the best too for sure!!!
and if i wanted regular with flush mount, i could take off the baffle and flip it.
I didn't read most of this so sorry if it was said but here is the deal.
The best way to do this is to plan to invert your subs before you build your box.
Next cut your baffle board on a set of saw horses before you ever attach it to your box. This way you can set the sub on top of the holes so you can get under the baffle and look up to center the subwoofer and screw it in place.
Now you have you alignment perfect.
After that you can use your jig saw to trim out any excess wood from the hole in your baffle until you feel comfortable that you are not going to harm the surround but still have enough meat for your screw holes to stay strong.
If you have a test tone disc then you can play the sub while its attached to the baffle (While its still on the saw horses) to check and garuntee that your sub is not rubbing the surround.
I have another method too. That involves cutting the hole to the normal size and then useing your jig saw or router to put an angle all the way around the mounting hole but this is much harder to do.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
With the weight of the sub I would double baffle so the inner baffle would not need to have as big as a hole cut in it as the mounting baffle would have because the the surround offers and angle on it as it reaches excursion and this would give you more meat for your screw holes.
First baffle needs the proper size hole and the second baffle needs a smaller hole.
Edited by ISO
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
