Teejaybee's 08 VW Rabbit DD / Kenwood build
I believe the GLI's have factory HID's, so it would be a plug and play. unlike these style headlights.
formerly known as Blue86f150
this sux camel dicks
okay heres a question for yall ima post it here and make a new thread
The Pos wire from my batt goes to a piece on my fuse box then i guess a wire from the alt goes to that "buss bar" and the batt only has one Ground wire so what do i do for big three?
To be honest, I would wait 'till you have an underhood battery to do the positive wire. I'm running a sundown 3k with a bat cap 4000 in the trunk. 2 runs of 1/0 (1+ and 1-) with the stock charge wire. Wired at 1 ohm I drop .2/.3 volts while driving down the road, but while at a stop it does drop. It will make it easier to just wire straight into the battery than try to mess with the fuse box that you are thinking of about doing.
yeah im kinda torn if i wana do it or not, but like they said in the electrical post just do it regularly with taking a pos from batt to alt fuse it and do the grounds
and im only planning on running a prime 500.1 and maybe a RF 2channel later on for front stage so idk we'll see ill save 20 ft of 4g for it id do 0g but i dont wana buy more wire lol
Anyone with a vw golf gti or rabbit ever take the center console apart where the gear shaft is and all that? or have a how to link for me because once i go to wire up my headunit i want to run wires under that spot but with just looking it dosnt look easy
If its like mine, it is just held in by clips. Just pry it up, and should come right off.
:popcorn:
alright thanks blue i need to just get your number lolz i should be doing more stuff monday my dad dosnt want me to do anything to this car but hey im paying for it and im not going crazy like my blazer all seats are staying in lol
