MustangGT Posted March 27, 2011 Author Report Share Posted March 27, 2011 ok thanks. it sounds really good, but until like volume 18 then it turns off. but when I lower the volume it comes back. it souls be the Eire not the amp right? Link to comment Share on other sites More sharing options...
08tahoe Posted March 27, 2011 Report Share Posted March 27, 2011 Certain jl amps shut off when the volts drop to low, I think to protect themselves. My jl audio hd 600/4 does that 2. Its normal Link to comment Share on other sites More sharing options...
MustangGT Posted March 27, 2011 Author Report Share Posted March 27, 2011 I love this page because of people like you. would 4 gage wire be enough. and sorry for my writing I'm using my iPhone. Link to comment Share on other sites More sharing options...
Rebel4055 Posted March 27, 2011 Report Share Posted March 27, 2011 That's what the amp takes so do it. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
08tahoe Posted March 27, 2011 Report Share Posted March 27, 2011 Ok I checked my manual and it sais if the battery voltage drops below 10 volts the entire amplifier will shut off to protect itself. Ill check the wiring thing but I'm pretty sure you need O guage wire depending on how many feet your amp is from the battery and then since I'm pretty sure your amp doesn't fit O guage then you could do like me and I have 0 guage from the batt to the trunk and then a fuse holder in between and then from the other side the wire turns into 4guage. I hope this makes sence Link to comment Share on other sites More sharing options...
Rebel4055 Posted March 27, 2011 Report Share Posted March 27, 2011 Depending on how far away your amp is? LOL that's funny. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
MustangGT Posted March 27, 2011 Author Report Share Posted March 27, 2011 it sure did. I could use a distribution bock to right? Link to comment Share on other sites More sharing options...
08tahoe Posted March 27, 2011 Report Share Posted March 27, 2011 Ok its kinda long but this is what the manual sais and like I said yours is more than likely the same. Run power wire from the battery location to the amplifier location, taking care to route it in such a way that it will not be damaged and will not interfere with vehicle operation. 4awg is recomemded for wire runs greater than 72 inces in length. Use of 8awg "I don't think this one applies to your amp though" power wire is acceptable for shorter runs, such as from a power distribution block to the amplifier or from a trunk mounted battery. Use a 2awg or 1/0 awg main power wire with a power distribution block when additional amplifiers are being installed with the hd600/4 and powered from the same main power wire. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted March 27, 2011 Report Share Posted March 27, 2011 4 gauge wire is all you need, but no less. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
MustangGT Posted March 27, 2011 Author Report Share Posted March 27, 2011 ok I'm in luck cause I have a brand new roll of 4 Gage. and one more question can I use power wire as ground to? Link to comment Share on other sites More sharing options...
