Axes are fun
I should fly to Australia and get this kid to do my hair! Then I can get a demo. :pardon:
hey thats me!
is it really a good idea to get someone holding an axe to do your hair? :P
u should build a concrete boxx first and only i will donate 40 dollars.. other then that looks awesome bro more updates
concrete is too heavy... but if this box flexes too much then its a possibility
^^^ clicky pics for build logs ^^^
Yeah.., perhaps I will let you all know what is going on..
- Rebuilding the old box with a 5mm plate around it
- Battery box with 6 Trojan 8 volt cells and then another 10 on top.
- 350amp 16-19 volt variable alternator just for starters..
- 2 amps putting out 23kw [rated power at 18 volt] between them.
- 4 x 15 inch subs
- 3 6.5 inch mids and 2 tweeters per side up front.
Gear pictures/models/specs etc will go up when we get it all :)
- 4 x 15 inch subs
What's the reason for the metal plate?
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
Strength and space, one 5mm layer of this grade of steel is comparable to at least 80mm of mdf. We dont have room for even another 18mm layer!
Steel cost me nothing, and working with steel is easy. The steel also doubles as the brackets on the edges.
Work from today..
Bending more steel
Checking the angles
Cover fitted over where the rear seats used to be
From front seats
Checking clearance from the box [Front stage amp will be going here]
Box supports welded
Everything is level :D
Just so you can see what will be happening
And that is about all until next weeks update..
This is going to be quiet impressive
im interested keep the updates commin :popcorn: :popcorn: :popcorn:
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
Okay we have been busy, more work to come on sunday and next tuesday..
Basically there will be 4 6.5" mids per door. They are Hardcore mids and will be receiving 640wrms rated power a door. soo around 1300wrms for the frontstage :)
Getting some rings made
approx layout
