naw this shits are new still ! or idk, i don't know what to do ! but i know i want 4 12s on 5-8k clamshell/tunnel !
what amp!? same on !?
You crazy, imma keep the same amp... and then do something crazy but no wall or anything
I don't want to criticize but the way your fuse holders are in the back , your rear batteries are not fused from the front of the vehicle only away from the amps. I just don't want to see your investment get wasted because the install is really good.
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
SO you want me to fuse the front batter to the back batteries is what you're saying? If so I cant do that lol
Ya exactly just move the two leads from the front of the car to the other side of the fuse holders and you'll be golden :good:
Wait im confuses now, im just gonna put 2 new fuses on the 2 positives under the hood that go to the back? Make sense?
Basically what he's saying is on your power runs from the front to rear batteries, you will want a fuse with 18" of each battery. Since you're doing 2 power runs, a total of 4 fuses. 1 on each run within 18" of the front battery, and 1 on each run within 18" of the rear battery.
Sick build bro, love seeing other Trailblazers / Envoys. Did you ever get a number on a straight burp out of the 18's?
YOu only need to add fuse holders if you want to fuse your amps. The quick fix is right now your 2 wires from the front are hooked to the passenger side of your fuse holders and they should be hooked to the driver's side instead.
Ok i'll change that hear soon!
THanks guys! And not metered yet, gonna meter it this sunday!
Good luck post up the results!
