863hurricane Posted March 28, 2011 Report Share Posted March 28, 2011 First off new to the forum but this site is awesome.. So on with my question Im a big fan of JL but was wanting to know if anybody had some good reviews on Polk Audio amp PA500.4 or should I go ahead and get the JL 300/4 need a good highs and mids amp Quote Link to comment Share on other sites More sharing options...
WillPwn4Food Posted March 28, 2011 Report Share Posted March 28, 2011 Quality wise, both are going to be outstanding. Polk Audio definitely knows what they're doing. The Polk will put out more power per channel 90wx4 vs JL 75wx4), but I believe the JL amp you listed is stable down to 1.5 ohms, as opposed to the Polk that I believe is stable down to 2 ohms. Quote Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
863hurricane Posted March 28, 2011 Author Report Share Posted March 28, 2011 Quality wise, both are going to be outstanding. Polk Audio definitely knows what they're doing. The Polk will put out more power per channel 90wx4 vs JL 75wx4), but I believe the JL amp you listed is stable down to 1.5 ohms, as opposed to the Polk that I believe is stable down to 2 ohms. Thanks for reply I might as well go with JL ..everything else in my truck is JL Audio a JL 1000/1 on 13w6v2 a JL500/1 on 2 JL10w3v3 and a JL 300/4 thats blown but going to send off to get fixed thats why I was asking about the Polk Audio Im sure Im going to be drowning the highs and mids out so want a clean higher power amp or should i just get 2 jl 300/4 Quote Link to comment Share on other sites More sharing options...
863hurricane Posted March 29, 2011 Author Report Share Posted March 29, 2011 Quality wise, both are going to be outstanding. Polk Audio definitely knows what they're doing. The Polk will put out more power per channel 90wx4 vs JL 75wx4), but I believe the JL amp you listed is stable down to 1.5 ohms, as opposed to the Polk that I believe is stable down to 2 ohms. Thanks for reply I might as well go with JL ..everything else in my truck is JL Audio a JL 1000/1 on 13w6v2 a JL500/1 on 2 JL10w3v3 and a JL 300/4 thats blown but going to send off to get fixed thats why I was asking about the Polk Audio Im sure Im going to be drowning the highs and mids out so want a clean higher power amp or should i just get 2 jl 300/4 Damn figured Id get more responses do people have bad things to say about Polk Audio or what Quote Link to comment Share on other sites More sharing options...
Torres Posted March 29, 2011 Report Share Posted March 29, 2011 nothing bad about polk audio. if it were down to it, i'd take polk audio over jl Quote Link to comment Share on other sites More sharing options...
08tahoe Posted March 29, 2011 Report Share Posted March 29, 2011 Quality wise, both are going to be outstanding. Polk Audio definitely knows what they're doing. The Polk will put out more power per channel 90wx4 vs JL 75wx4), but I believe the JL amp you listed is stable down to 1.5 ohms, as opposed to the Polk that I believe is stable down to 2 ohms. Thanks for reply I might as well go with JL ..everything else in my truck is JL Audio a JL 1000/1 on 13w6v2 a JL500/1 on 2 JL10w3v3 and a JL 300/4 thats blown but going to send off to get fixed thats why I was asking about the Polk Audio Im sure Im going to be drowning the highs and mids out so want a clean higher power amp or should i just get 2 jl 300/4 Why don't you look into the jl hd600/4 instead. i have the jl hd600/4 and love it. I tried the 300/4 and its bigger and less watts and getts hotter but I think it cost less. The hd600/4 is double the watts and smaller. Quote Link to comment Share on other sites More sharing options...
863hurricane Posted March 29, 2011 Author Report Share Posted March 29, 2011 I actually thought about the HD600/4 but Ive got so much money wrapped up in this already and work gets a little slow in the summer so I kind of need to slow down still need alternator or do you think I can get by with adding my stinger battery in the back? Im hoping to be done with this install in 2 weeks Quote Link to comment Share on other sites More sharing options...
08tahoe Posted March 29, 2011 Report Share Posted March 29, 2011 I actually thought about the HD600/4 but Ive got so much money wrapped up in this already and work gets a little slow in the summer so I kind of need to slow down still need alternator or do you think I can get by with adding my stinger battery in the back? Im hoping to be done with this install in 2 weeks well the hd600/4 is expensive but its supposed to use less power. But I don't know about adding your battery before u upgrade your alt maybe someone else can answer that but if I'm not wrong its better to have your alt first cause if your gonna put another battery then your alt is gonna have to charge two batteries instead of one plus run your system. Quote Link to comment Share on other sites More sharing options...
