ChevyBoy95 Posted March 28, 2011 Report Posted March 28, 2011 I want to put in an extra battery (2k on stock alt, upgrading alt in a month) and was wondering when it is in how to disconnect everything correctly. In the sense of disconnecting all the grounds. (back batt will most likely share the amps ground.) more in the sense of which side to start, from back batt to front or front back, or does it not matter? Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
RickyFriery97 Posted March 28, 2011 Report Posted March 28, 2011 what do you mean disconnecting? like when your installing it? 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
ChevyBoy95 Posted March 28, 2011 Author Report Posted March 28, 2011 what do you mean disconnecting? like when your installing it? I mean once it's already in and let's say I need to switch amps, what order do I disconnect it in? I think I no but I want to be sure. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
cubs_fan0718 Posted March 28, 2011 Report Posted March 28, 2011 Just remember always remove the ground first and hook it back up last. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
RickyFriery97 Posted March 28, 2011 Report Posted March 28, 2011 Just remember always remove the ground first and hook it back up last. ^x2 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
ChevyBoy95 Posted March 28, 2011 Author Report Posted March 28, 2011 Yea I knew that, just making sure, rather e safe than sorry. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
