I can't watch YouTube vids right now but if you explain I may be able to help you out
one of my wires are getting hot, when i switch a lever for cold air, when i initially connect the two wires it only blows out hot air from the blower motor
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
is that what makes the vents open up and close?
how could i test that?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
This website does a good job explaining of the AC system in your car works http://www.familycar.com/ac1.htm it could also be as simple as a rerigerent leak. What make and model is the car?
86 chevy monte carlo
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
The compresser is under the hood
i see now, i thought that was the A/C clutch, guess its the same thing. but when the A/C did work the thing on the front spun when the
A/C was on.
it no longer spins, could it be something electrical or do i have to replace that?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
It could be a few things a from a bad bearing, pulley or belt to having to replace the whole compressor.
On a different note if it is just a simple as replacing the pulley or something and it still doesn't work it could be a refridgerant leak and since it's an older car before te new EPA laws were set I am going to assume it's r-12 and that it hasn't been upgraded to r-134a and the problem with that is that you have to be EPA certified to purchase r-12 so you wouldn't be able to fix it your self
you win some, you lose some
