HotRodHam Posted April 1, 2011 Report Posted April 1, 2011 If i were to et 2 DC level 4s D2 running on 1 AQ 1200D per sub running at 1 ohms each. would i need an alt or u guys think an extra battery would be good enough 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
Loudcivic Posted April 1, 2011 Report Posted April 1, 2011 well i would say you would need a decent size battery for the back and upgrading the battery up front wouldnt be a bad idea. ill running a sundown 2500 and i have a 170 amp alt a stinger spv35 and 2 stinger spv70 battery's. i may have gone a little on the overkill side but who knows lol 2015 silverado crew cab nothing atm but soon...
RickyFriery97 Posted April 1, 2011 Report Posted April 1, 2011 Why not just get the AQ2200D instead of having two amps? it would de alot easier to tune and you wouldnt have to gain match the amps you could probally get away with having the biggest XS power batt under your hood and doing the big three but you would have to watch your voltage i would do atleast one big batt in the back and a upgraded one up front and the big three in 1/0 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
HotRodHam Posted April 1, 2011 Author Report Posted April 1, 2011 Why not just get the AQ2200D instead of having two amps? it would de alot easier to tune and you wouldnt have to gain match the amps you could probally get away with having the biggest XS power batt under your hood and doing the big three but you would have to watch your voltage i would do atleast one big batt in the back and a upgraded one up front and the big three in 1/0 i was thinkin bout this but isnt .5 ohms bad for those amps? or can they do it cuz it only says 1ohm stable 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
RickyFriery97 Posted April 1, 2011 Report Posted April 1, 2011 Why not just get the AQ2200D instead of having two amps? it would de alot easier to tune and you wouldnt have to gain match the amps you could probally get away with having the biggest XS power batt under your hood and doing the big three but you would have to watch your voltage i would do atleast one big batt in the back and a upgraded one up front and the big three in 1/0 i was thinkin bout this but isnt .5 ohms bad for those amps? or can they do it cuz it only says 1ohm stable do you already have the subs? if not buy two Dual 4 ohm subs and wire at one ohm i wired mine to .25 but i have beefy electrical i wouldnt do .5 daily unless its CLEAN un clipped power and very sturdy electrical 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
HotRodHam Posted April 1, 2011 Author Report Posted April 1, 2011 Why not just get the AQ2200D instead of having two amps? it would de alot easier to tune and you wouldnt have to gain match the amps you could probally get away with having the biggest XS power batt under your hood and doing the big three but you would have to watch your voltage i would do atleast one big batt in the back and a upgraded one up front and the big three in 1/0 i was thinkin bout this but isnt .5 ohms bad for those amps? or can they do it cuz it only says 1ohm stable do you already have the subs? if not buy two Dual 4 ohm subs and wire at one ohm i wired mine to .25 but i have beefy electrical i wouldnt do .5 daily unless its CLEAN un clipped power and very sturdy electrical i just looked this up and i decided ima get the D4s cuz ill save like 150 bucks if u buy 1 2200d instead of 2 1200ds which i can spend on some dynamat haha 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
RickyFriery97 Posted April 1, 2011 Report Posted April 1, 2011 Why not just get the AQ2200D instead of having two amps? it would de alot easier to tune and you wouldnt have to gain match the amps you could probally get away with having the biggest XS power batt under your hood and doing the big three but you would have to watch your voltage i would do atleast one big batt in the back and a upgraded one up front and the big three in 1/0 i was thinkin bout this but isnt .5 ohms bad for those amps? or can they do it cuz it only says 1ohm stable do you already have the subs? if not buy two Dual 4 ohm subs and wire at one ohm i wired mine to .25 but i have beefy electrical i wouldnt do .5 daily unless its CLEAN un clipped power and very sturdy electrical i just looked this up and i decided ima get the D4s cuz ill save like 150 bucks if u buy 1 2200d instead of 2 1200ds which i can spend on some dynamat haha yup sounds good man glad i could help 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
HotRodHam Posted April 1, 2011 Author Report Posted April 1, 2011 thanks 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
Supercharged DCs Posted April 1, 2011 Report Posted April 1, 2011 To run the Aq2200, I'm going to get the XS D3400 under the hood and do the Big 3 in 1/0gauge, you can probably do the same and it should run nicely Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
