Noob confused about amp
bumpinTL364
Hey all I'm looking at the Dayton SA100 amp to use for a set-up in my room. I see that there are two different types of inputs (low and high respectively) one having RCA connectors and the other with banana/bare wire connections. The low level has just inputs for right and left where as the high level has 2 pairs of negative and positive input connectors and also says "from amplifier" above them. What's the difference between the two? Also I see there are low and hi outputs for speakers with RCA and banana/wire outputs respectively in addition to the wires on the other side of the plate that go to the woofer. What's the difference between these outputs? Can I wire my speakers directly to this amp or are these like pre-outs to be run through another high/mid amp? Also how can I know or figure out how much power these channels put out? I can attach a pic if needed but it's linked here: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-802 thanks all for the help I've gotten so far!
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
the high inputs are for people that don't have rcas. you should be able to run two speaker wires to it(right/left) going in and then have another set going out. if you have the rcas available use them it will give you a better sound.
I have 2 speakers with RCAs but they're only 5watts each I think (off a coby 2.1 system). would this amp blow them?
Try it and tell us :P.....................................................................................................yes they would turn crispy
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
I don't doubt that.... I can't seem to find any specs anywhere! all i see is 8ohm 75 watts and 4ohm 100 watts, which is for the woofer.... halp !
Well, there both
If it's an 8ohm speaker you connect, it would give it 75 watts.....100 watts if it's a 4 ohm speaker.
  • pa-pa-platypus
  • Who's Online   0 Members, 0 Anonymous, 1278 Guests (See full list)
