Chevyboy95's Ext Cab Build (New Vid pg6)
you gonna paint the new dustcap black? I love the look of it. :drink40:
Maybe I missed it, what are the specs on that alt?
just a little 200amp peak, 125amp idle. better than the stock 105 peak.
and to the other guy above, 14.2ish volts charging, 2 ohms, ~3100 rms.
FUCKING SICK BUILD!! Nice as hell man! Love it. I have the same truck but mine is green and has a 4 inch lift. I am 15 and in high school so i have friends and stuff that will end up wanting a ride in the back seat.. I have contemplated taking the seat out so i can have better subs. Do u ever miss ur back seat?
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
  • 1 month later...
Back seats are lame. :)
You will find out quickly, people will constantly ask for rides. The fewer people you can seat, the better. :)
So most of you know that I had my wreck :facepalm: , well now its time to rebuild basically from the ground up.
Things will be done in this order:
1. Headunit in
2. Deaden everything pretty much (passenger side, back, and floor)
3. Alternator (3,4, and 5 might come after 6 and 7 so i at least have tunes)
4. Batteries in
5. 1/0 throughout (2runs of pos and neg)
6. Kicks and doors (speakers)
7. Mids highs amp
8.Temp L7 15 in my old DC level 4 15 box
9. Sub amp in
10. and so on...
List of equipment:
-2 Kinetik HC1400s, 1 Kinetik HC800
-Mechman 200a Alternator (14.2 charging hot)
-Soundstream Goliath Tarantula XXX-6500 @ 2 (~3kwrms)
-DC Level 5 18
-Cadence Wiring (~50ft of 1/0, ~100+ ft of 14ga, 15ft of 8ga)
-Oxygen Audio Spiral F150 for mids and highs
-Dayton Audio PA165-8s and ?(maybe type r coaxes or idk)
-Audiotechnix Sound Deadener
-Alpine CDE 125BT headunit (might upgrade so i can have a 4v preout)
-DB Link fuse holders
cant think of anything else...
Box for the DC will probably be BCarter's Design he did, or a VERY close tweak of it.
~6 cubes, 33-35hz, 120-135sq in of port (i say tweak because i think +125 sq in would be overkill and cause issues with power)
Temp box for the L7 is a old one of mine, 3.4 cubes, 33hz with 3 4in pvc tubes. Absolutely hammered lows so hopefully it does the same with the L7.
Went to the shop to see how the truck is. Floor is pulled back straight, now the cutting will begin, looks like it should be done just before christmas hopefully.
as it sits right now, doesnt look like much, but a bit has happened.
Dude that sucks! :( was it considered totaled?
My Truck Build
