pektel Posted April 5, 2011 Author Report Posted April 5, 2011 I'd stick around 2 - 2.5 cubes with pretty much RMS power Thanks for the input! Does it make a difference which way I mount the port? Does it have to be on the same wall as the sub itself? These are things I don't know has a bearing on performance. Quote
dwright27 Posted April 5, 2011 Report Posted April 5, 2011 I would do sub back and port back. Also, The sidewall isn't the first number. That's how wide the tire is. the 2nd number denotes the height/profile of the tire. And the third numbe is inch size. So if it's 245/40/18 then it's 245 millimeters ( I think that's the unit they measure in ) wide 40 millimeters tall, and 18"s in diameter. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Carroot1 Posted April 5, 2011 Report Posted April 5, 2011 should totally make this a sleeper system... your car is so nice! Quote
pektel Posted April 5, 2011 Author Report Posted April 5, 2011 (edited) Right, the first number denotes tire width in mm. The second number is the ratio of width that the sidewall is high. So, a 345/40 would have almost a 5.5" sidewall. My 245/40 have a 3.86" sidewall. That's an overall diameter difference of 4" I would do sub back and port back. Also, The sidewall isn't the first number. That's how wide the tire is. the 2nd number denotes the height/profile of the tire. And the third numbe is inch size. So if it's 245/40/18 then it's 245 millimeters ( I think that's the unit they measure in ) wide 40 millimeters tall, and 18"s in diameter. Edited April 5, 2011 by pektel Quote
pektel Posted April 6, 2011 Author Report Posted April 6, 2011 Also dwright, would it hurt to port up? I have 2 spots in the rear shelf where 6x9's were available as a factory option. Thought about maybe aiming the port through one of those into the cabin. Quote
matt402 Posted April 6, 2011 Report Posted April 6, 2011 (edited) http://www.the12volt.com/caraudio/boxcalcs.asp id go with 2 cubes tuned to 30-34hz. Edited April 6, 2011 by matt402 Quote
dwright27 Posted April 6, 2011 Report Posted April 6, 2011 No it wouldn't hurt. May help. If your seats fold down, you could seal everything off from the trunk. If you wanted to port through the rear deck, you could make mounts for the awroports out of MDF to bolt them down and secure them. You have a PM coming! Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
pektel Posted April 6, 2011 Author Report Posted April 6, 2011 should totally make this a sleeper system... your car is so nice! Thank you, sir. Sleeper system is definitely an option. I actually prefer having nothing visible from the trunk side. Very clean looking. Quote
RAM_Designs Posted April 6, 2011 Report Posted April 6, 2011 2-2.25ft^3 with a low 30's tuning. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
