marquettefan247 Posted April 5, 2011 Report Posted April 5, 2011 Hey, I am installing a XO Vision (XOD1736) 7" Widescreen Enhanced Resolution Multimedia Receiver in a 1996 Saturn SL2. Wired everything up but the brake wire. I know this is the wire to allow dvds to play while driving. So in accessory everything runs fine. Once I turn it on it says DVD with a blue screen and i cant get it off of that. I took the brake wire and hooked it in with the ground wire and no difference. What am I doing wrong? 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
rubbernutz1 Posted April 5, 2011 Report Posted April 5, 2011 well sum decks will work that way and some wont. my old clarion screen deck i had to hook that wire to a switch. every time i wanted to watch a dvd on it i had to flip the switch on then back off to send a grounded signal to the deck to make it work. try that and see of it works all you need is a cheap lil toggle switch for it.
dwright27 Posted April 5, 2011 Report Posted April 5, 2011 Probably what it needs ^ 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
marquettefan247 Posted April 5, 2011 Author Report Posted April 5, 2011 I will try. So I am guessing it will go POWER:Power ACC:brake line GROUND: spot on the body 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
rubbernutz1 Posted April 5, 2011 Report Posted April 5, 2011 ? u lost me dude. just hook your power accessory and grounds up like you would normally but run the park brake wire to the toggle switch then run a wire from the toggle switch to a ground. more or less the same way u have it now except u have a switch in line of the brake wire
dwright27 Posted April 5, 2011 Report Posted April 5, 2011 I will try. So I am guessing it will go POWER:Power ACC:ACCGROUND: spot on the body and the brake wire Fixed 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
marquettefan247 Posted April 5, 2011 Author Report Posted April 5, 2011 got it.... Put it in and it works with that switch!!! thanks guys 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
