Leave that bass boost off on both the amp and HU, unless you have a scope do not even attempt to use it. Check the amp output to the sub(s) and also check the voltage to the amp with the car on.
Its always off on the HU but I will turn it off on the Amp and I will go check those two real quick and post back, appreciate the help man.
Edit: Voltage at amp is 14.4 and on the sub output the highest it went on a sweep was 12.3 AC volts. Still no sub moving, so i'm assuming that means a voice coil is messed up?
Edited by Dinzu
push in on the cone to see if u hear a crackly popping sound. if u do the coil if screwed, time for a recone. but like the other dudes said put the coils on a meter and git the ohms reading. i just reconed a 18 RE aduio that did the same thing. turned out to be a melted spot in the coils and it had to be reconed.
If you have access to another woofer, just do a simple swap to see if it's the sub for sure. If the second sub doesn't work then you know you have a bad amp. Two birds with one stone.
The amp only went to 12.3 AC volts? That's only like 150 watts...granted that would move the sub though.
Check the voice coils on your sub with your DMM and see what they read.
Edited by bumonskateboard6
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Glad we could help ya! Take it easy on it next time :santa:
One more question, could going too low HZ wise one time do this? box is tuned to 31 hz and my subsonic was around 21-22 and it bottomed out pretty hard one time on a screwed song yesterday morning, then broke yesterday night barely hitting.
Edited by Dinzu
