Hey guys I'm lookin to run some components off this amp..the specs for the amp/speakers are below..my question is would I be able to safely put 250 watts to the speaker if the peak is 300
Amp specs:
Items Features Voltage 175.4
Output Power (RMS)
at 4 ohm 14.4V 175Wx4
at 2 ohm 250Wx4
Speaker specs
Peak: 600 watts per set / 300 watts each side
RMS: 300 watts per set / 150 watts each side
Thanks
Posted (edited)
No, are you sure they're 2 ohm? Cause I feel it's safe to run 175rms to s speaker that's 150rms if theyre 4ohm.
Edit: what speakers are you looking at?
Edited by bumonskateboard6
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
They are the re audio xxx 6.5" components..Pretty sure they are 2..can u recommend any 6.5" components and 6x9 coaxials..perferably the same brand for both..lookin to run these speakers off a dc audio 175.4
Ah I was wondering if they were the RE XXX components cause you said they were 2 ohms...
Those are the only speakers I'd feel comfortable running at 2ohms off that amp, however I'm still not sure how long they'll last. Talk to Ray or James on here I'm pretty sure they've run a lot of these over their RMS ratings and can give you some good info.
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
Posted (edited)
Uh... Here's a crazy idea, don't turn the amp all of the way up? No one said you could only use it's full RMS. You can set it to run around 150-175 at 2 ohms by backing off of the gain slightly.
Although you'd be better off to find 4 ohm components, as most 4 channels are more efficient and tend to sound better at 4 ohm loads.
Edit: typo
Edited by Autruche
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
