BackYardSoundZ Posted September 25, 2007 Report Posted September 25, 2007 I just put in an alpine for my cousin and everything worked fine for the first day, he previously had a sony and switched for better quality but the sony was workin fine. Im not sure if its the cd players fault but his 4 channel will cut out when the volume is to high, the amp was never touched and all the cd connections are soldered and fine, the only thing i can think of is the pre-amp on the alpine is higher then the sony but they are both rated @ 2 so i didnt adjust the amp at all. Im gonna try adjusting the gain but i just wanted to post this to see what you guys thought. P.S - The amp's power led will go out completly but no protection, and itll only happen for a split second (reoccuringly), radio or cd. Pc, BYS
dwright27 Posted September 25, 2007 Report Posted September 25, 2007 maybe not enough battery power. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
BackYardSoundZ Posted September 25, 2007 Author Report Posted September 25, 2007 maybe not enough battery power. well he used to have a goliath in the trunk powered by an MA audio amp with out any problems electrically and all i did was take them out when he sold them so im thinkin hes good with power but thnx for the reply bro.
FieroGrande Posted September 25, 2007 Report Posted September 25, 2007 Maybe you have a short in the wire somewhere or the remote wire is comming lose.
dwright27 Posted September 25, 2007 Report Posted September 25, 2007 well, reason why i say battery power is my eclipse deck would kinda "pulse if you would and dim and brightten, when my voltage got low, and came came back up. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
BackYardSoundZ Posted September 25, 2007 Author Report Posted September 25, 2007 well, reason why i say battery power is my eclipse deck would kinda "pulse if you would and dim and brightten, when my voltage got low, and came came back up. ya you know you could be right i mean batteries do go bad but his cd player isnt showing signs of it its just the amp will cut in and out real quick and only when the volume is high, ima try adjusting the amps gain ill let you guys know if it solves it.
GHOPPOMAN Posted September 25, 2007 Report Posted September 25, 2007 disconnect the radio turn on at the amp and jump the remote wire from the pos. and see if it still cuts out. if not then u have a turn on prob. (which is what i think it is!)
ChevyBoy Posted September 25, 2007 Report Posted September 25, 2007 disconnect the radio turn on at the amp and jump the remote wire from the pos. and see if it still cuts out. if not then u have a turn on prob. (which is what i think it is!) x2. it could be a bad remote wire in the head unit.
