My specs right now are 2.47 Cu 35.05Hz with 3"x13"x25.5" port, port is bent at 14" into 11.5", 36" Port area. I would like to know if that .07 on my boxes Cu would be enough for bracing. Or if anyone knows about how much displacement would be there from bracing the inside of the box?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I guess the rule of thumb for any overkill bass setup is to brace it more than you think is necessary. I've used front to back 2" x 2" crossbars, about 4-5 to stable it out...
If you can calculate port displacement, do the same thing to the total of bracing material!
There are a few ways, metal bars threaded that u attach with nuts and washers. Stable when larger dimensions.... like M16 and above. Try flexing at store! The advantage of these is that they dont displace much volume at all.
Using internal additional walls, that are cut out wholes in the middle allowing for airflow is very strong bracing as it reaches all walls.
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
I used 3 1" wooden dowels from top to bottom, left t right, and front to back in my setup. 18" hdc3 on xx colossus. Holds up great, cost me next t nothing, and does not displace a whole lot as compared to other methods.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
ty
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 563 Guests (See full list)
