<------- those 2 AQ Hdc318s im gonna be using mdf with a double front baffle. and interior bracing as well should i glue pieces of 2x4s to make level then put down the bottom piece of wood then fill rest with foam?
Bingo baby...you took the words right out of my mouth. Just screw your bottom 2x4's to the metal of the car, or bolt them to make sure they are extra sturdy, then screw the other 2x4's on top of one another until they just clear the top of the hump...place you a piece of .75" birch or mdf wood on top of it, and foam that bad boy up!
start with a 2x4 base
and might i suggest getting some flat bar (flat steel) and drill hole in it same size as seat bolt and mount it to that then bend it and tie it in to the false floor
i donno if that makes sense or not but if you have questions ask
R.I.P!
(Nov-29-2009)
92 explorer
current build
Im ready to get to work on this.. depending when i have free time i work a fuck ton.
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Thanks for all the input guys ill post pics when i get it started
Hows the gas leak ???
haha about that... its fixed ;) moving this to build log.. so mod if you see this please lock
/thread
