RickyFriery97 Posted July 21, 2011 Author Report Posted July 21, 2011 Ricky can you go into more detail about how you ran your 1/0 pos wire to the back? I now have to do the same thing with 8 runs of pos/neg, heh... sure bro, always down to help a fellow tahoe owner!! but i have a XS power D3400 in the second battery tray, i out my fuse holder on top of the fuse box, then droped it down behind it down to the frame then fished it back ziptying it along the frame then under the back seat is where i pulled the wire into the cab just drilled holes in the cover, and the body and used grommets hope this helps 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted July 21, 2011 Author Report Posted July 21, 2011 OK pretty straightforward. Only part I'm leery about is I need to drill more or a lot bigger holes in the floorpan than you did because I'm running 8 wires instead of 1. If I drill them too close together I will be significantly weakening the floor in the area. Gonna have to think about this, maybe there is some hidden route into the cabin I can find that won't require drilling. yea 8+ runs is gunna be tricky, maybe run it farther back and come in on the flat cargo area? id have to look under there again, i will tomorrow and brainstorm some ideas for ya, ill have atleast 4+runs on my rebuild so i needa look any way 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted July 21, 2011 Author Report Posted July 21, 2011 OK pretty straightforward. Only part I'm leery about is I need to drill more or a lot bigger holes in the floorpan than you did because I'm running 8 wires instead of 1. If I drill them too close together I will be significantly weakening the floor in the area. Gonna have to think about this, maybe there is some hidden route into the cabin I can find that won't require drilling. yea 8+ runs is gunna be tricky, maybe run it farther back and come in on the flat cargo area? id have to look under there again, i will tomorrow and brainstorm some ideas for ya, ill have atleast 4+runs on my rebuild so i needa look any way I looked around and am focusing on finding an area that's covered by one of the two big side trims to come in on. My current idea is to come in from the big square indentation of sheet metal that surrounds the gas cap. That's non-stressed sheet metal and I can hack it up as much as I want, and come in cleanly into the cabin. sounds like a plan to me! now get to it! lol 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted July 22, 2011 Author Report Posted July 22, 2011 finished up deadning the rear hatch and got the panel on hmm what to do next to this truck, any suggestions? 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted July 22, 2011 Author Report Posted July 22, 2011 OH and go vote for me in July SOTM!!! come on, you know you want to, here ill make it easy for yall http://www.stevemeadedesigns.com/board/topic/115237-july-2011-sotm-vote-sponsored-by-dc-audio/page__p__1617101__fromsearch__1#entry1617101 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
jg23 Posted July 22, 2011 Report Posted July 22, 2011 Ricky I'm trying to understand how you hooked up the OEM power wires to the D3400. In my Tahoe, on the top of the OEM battery there is some complicated thing with two OEM wires from the fuse boxes going through a 175-amp fuse connecting to the terminal (with the dinky-ass 4-gauge from the alt coming in directly). In your pictures I don't see how you hooked this up to your D3400 - is it on the side of the ibar terminal? I have purchased the ibar terminals, but did you buy any additional terminal adapters to make all this fit? x2 I'm curious bout this too. I got a d3100 coming tomaro 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
jg23 Posted July 22, 2011 Report Posted July 22, 2011 Ricky I'm trying to understand how you hooked up the OEM power wires to the D3400. In my Tahoe, on the top of the OEM battery there is some complicated thing with two OEM wires from the fuse boxes going through a 175-amp fuse connecting to the terminal (with the dinky-ass 4-gauge from the alt coming in directly). In your pictures I don't see how you hooked this up to your D3400 - is it on the side of the ibar terminal? I have purchased the ibar terminals, but did you buy any additional terminal adapters to make all this fit? x2 I'm curious bout this too. I got a d3100 coming tomaro Ahh hell no how did I miss your build log? Got 13 pages to go through and steal ideas... Lol cause I don't got money. Haven't updated in a while. Besides a new box n batt tomaro 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
RickyFriery97 Posted July 22, 2011 Author Report Posted July 22, 2011 gotcha Broham thanks bro! 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
BeatBox Posted July 22, 2011 Report Posted July 22, 2011 ur exited to get the news on the subs this morning! less than a wk for mine too
