DC Sound Lab
the sub can take 3k as long as you dont clip at all. i dont recommend you running at .5ohm.
why wouldnt you recomend running at .5 ohm?
if he had a 1ohm stable amp, and good power supply, run it at 2ohm daily, and 0.5 for burps in competition.
as long as the amp is getting enough power it will be fine. after box rise etc it will be geting more than 0.5 any way.
my amps run daily at 0.7 and are fine.
not saying you are wrong/arguing with you, just asking a question :)
i can usually tell by the question, the persons experience level and i give an answer based on that. going to half ohm means seriously pushing the limits of your equipment and you need to be ok with blowing something up. I dont think the OP is at that stage.
so while battling imp rise with a low nominal load is the correct answer for some people (i was doing it myself) its not the answer for everyone.
aahhhh ok cool. was just wondering is all :)
altho im not ok with blowing anything up i still run under impedence, but keep an eger eye on volts and how hot stuff gets :)
its not just the amp in question here. its a 4000w amp wired to .5ohm on an XL. box too big, subs gone. clip a little, subs gone. play too low, subs gone.
when i ran .5 or even .25, i put my amps in fan cooled chambers. lower nominal to battle rise, fans to battle all the extra heat. its amazing how much a little airflow can help.
Edited by skittlesRgood
thats on my to do list too, add a couple of fans. the amps go get pretty warm, not too hot but warm enough for my liking. i dont think id like to run any lower than .5 but if i end up getting another pair of my amps and strapping them, i may have to run 0.35 as i dont want to go as high as 1.4 i loose a lot of power doing that.
heat is the #1 killer of amps. well maybe #2 is you add user error lol. get them fans in there :good:
this amp is 1500wrms... :ehh:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
he said "3k at 2ohm" i was more going off of that. maybe he meant a different amp, not sure.
Or 2 strapped?
then he means .5ohm strapped. and that means .25 each. =@
  • Who's Online   0 Members, 0 Anonymous, 4362 Guests (See full list)
